- 1,965
- 442
- 68
- Culver City, CA
With the axle caps on, king pins greased and brake dust/cover plates installed, the front tires went back on this morning. I properly torqued the lug nuts and axle cap nuts.
A word about the cover plates...bolt them onto the spider before you install them on the knuckle. The bottom most mounting bolt is impossible to install as the bottom of the knuckle does not lend to much clearance to work in there. The top plate went on fine and the bottom is held on with one bolt. The bottom plate feels secure but rattles a bit.
