- 1,430
- 1,191
- State College, PA
Don't hold your breath!!!Now if I could just get AntennaClimber to give me his amazing M101A2 Camper trailer……………
One of these days I’ll have a trailer like yours.Don't hold your breath!!!
I have the exact same pulley and belts on my M1028. I haven’t had any belt squeal or had to tighten the belts in over a year, and I drive my truck weekly. Definitely a great upgrade!So far, so good. I really haven't had a chance to drive it and put some miles on it just yet, but I have run the engine and it seems to be working just fine...and not one hint of belt squeal. Now they do stick out of the crank, water and PS pulleys just a slight bit, as they don't fit flush like originals, but only very small amount. If you look at my photos, you can get a idea of how they fit.
So the myth is true; the M1008 is a pussy magnet
There were three up there but by the time I got my phone out only that one stayed.I always thought that the M1008 was a pussy magnet
Please post videos of this thing running when it's complete. This is one of the more impressive machines I've seen in my life.Got all the ancillary systems completed on the driver's side of the new drivetrain prior to re-installing the inner & outer fenders next week.
Rivnuts that spin are a drag. I assume getting to the back to hold them with a vice grip isn’t possible? If not, it might be worthwhile to tack them with a welder to keep them captive and remove the bolts or drill them out. If you have a welder handy or know someone who does.Finally got around to tearing into the M1009, I have to have it running better etc. before the Graves Mtn. rally on Labor Day weekend.
Removed all the remaining radio racks and stuff from the back. They will be reinstalled over the wintertime once I get some other interior stuff done. I plan to repaint it and get new floor coverings in there first to replace the (mostly) missing rubber mat and padding.
PO or somebody put a new dash in it, it's gray. I like the fact that it's in great shape. Not diggin' the gray color. I might see if I can dye it burgundy or something to better match the original. Note the vent openings in it, but not the hole and bracket where the VRC switch box needs to mount.
Another project, the stupid riv-nuts. All the bolts are out except three, which are seized to the riv-nuts and the nuts just spin. Who invented these things?
Next weekend - fuel filter system upgrade and draining the 10-yr-old diesel out of the tank. Fun times in 90% humidity...
View attachment 950315View attachment 950317View attachment 950318View attachment 950319View attachment 950320
You can take a small die grinder and remove the outer lip of the spinning rivnuts and then simply push it inwards to expose the hole. Then just install a new Rivnut in the same hole. So easy a Cave Man can do it.Rivnuts that spin are a drag. I assume getting to the back to hold them with a vice grip isn’t possible? If not, it might be worthwhile to tack them with a welder to keep them captive and remove the bolts or drill them out. If you have a welder handy or know someone who does.
