- 4,163
- 7,271
- MA
Glad it all worked out for you. That 831 sounds like a perfect size for most of what you needed. Using that little of fuel is perfect. Makes me want to get one that size when I don't need the 803.Ended up with about 30" total, no power still. Ran the 003 for a while so wife could do laundry and cook, plus well pump and cords running to M.I.L next door., switched to the 002 when the load was lighter. Then ran the 831 ( with Kurt's controller board keeping it going! ) through the night. was pulling about 2kw with 6 fridge/freezers, wood stove blowers, some lights, computers etc. Surprisingly it ran about 9 hours and only used slightly over a gallon of fuel.
Back on 002 now for the day.
Before I had a larger battery on the inverter, I used an 831 for overnight loads as well. It worked really well to keep the basic lights/fridge going.Glad it all worked out for you. That 831 sounds like a perfect size for most of what you needed. Using that little of fuel is perfect. Makes me want to get one that size when I don't need the 803.
Awesome setup Ray! That is some serious prep work paying off.View attachment 963073
Thank you... glad I was ready for this and my wife and daughter are not complaining at all anymore!
Here's a couple pics of my setup.
Looking from the door opening, 003A on the left, 002A on the right and the 813A in the front. all in an 8x10 shed with lighting and powered ventilation. Exhausts are flex mounted and run out through the side walls ( with less clearance to combustibles than ideal ) but after 24 hr. the wood was no warmer than the air in the shed. The 003A has a set of 6TL batteries in it, with a 2 channel Noco charger of course and the 002 and 831 are jumped off it with slave plugs. on the little shelf you can see the synchronizer box so I can shift on the fly ( like tonight when my M.I.L decided to use the oven without telling me. The 002 took the load of both houses and the oven etc, but bogged when the well pump came on, so I shifted to the 003 until dinner was done. My son did all of this setup at like age 13 I think, including the underground that brings power into the shop's sub panel. All I did was fund the project!
It's about 70 degrees in the shed and with no insulation the icicles from the snow melting off the roof are touching the ground.
Not looking forward to 4 more days of burning dead dinosaurs, but if that's what it takes...
I've been dealing with these machines for 12+ years and this is the first time I've needed to run for more than a few hours. Definitely good exercise for the machines.
The shed is about 120' from my bedroom window and being enclosed, I don't hear them running at all, but I can hear the neighbor's gas generator screaming away at 3600 a good 700+ feet away on the other side of the road!
