2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck ,M220, Truck, Tractor M221 and Water Tank Truck M222
Guyfang
28,630
Burgkunstadt, Germany
TM listing for 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 and Water Tank Truck M222
LO 9-8024
TM 9-819A dated 1951 Superseded by TM 9-8024
TM 9-1819AA Superseded by TM 9-8025-1
TM 9-1819AB Superseded by TM 9-8025-2
ORD 9 SNL G-749
TM 9-1819AC dated 1952
TM 9-1826C
TM 9-1826D
TM 9-8024 dated 1955
TM 9-8025-1 dated 1958
TM 9-8025-2 dated 1957
TM 9-8601
TM 9-8627
TM 9-2920-225-34 dated 1981
TM 9-2920-225-34P dated 1974
TM 9-2920-247-34 dated 1966 wc#1
TB 9-2855-17
TB 9-2855-40
All Publications listed in red, are not available in our TM forum. If you should have a copy of anything missing, it would be nice if you could upload it in the TM upload forum, or send it to @Mullaney or @Guyfang
I would like to thank member @M1224 & the Vancouver Gunners, 15th Field Artillery Regiment, The Royal Regiment of Canadian Artillery web page, for their contributions.
I want to add here, that I have taken the liberty to post an old and newer TM or document when ever possible. So take the time to look at the cover page to each document to make sure it covers your vehicle.
Guyfang
28,630
These are the older Manuals:
TM 9-819A dated 1951, Parts 1&2
Operators Manual, 2 1/2 Ton, 6X6 Truck, M135
TM 9-1819AA
Ordnance Maintenance for the Engine, (GMC Model 302) of the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
TM 9-1819AB
Ordnance Maintenance for Hydra-Matic Transmission, (GMC Model 302M) of the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Ordnance Maintenance of the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
ORD 9 SNL G-749
Parts Manual for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Guyfang
28,630
New Manuals:
LO 9-8024
Lubrication Order for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Operation & Ordnance Maintenance of the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
TM 9-8025-1 dated 1958 (Parts 1-4)
Ordnance & Depot Maintenance of the Engine, (GMC Model 302) for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Ordnance & Depot Maintenance of the Hydra-Matic Transmission, (GMC Model 301MG & 303M) for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Guyfang
28,630
TM 9-8627
Electrial Equipment (Delco Remy)
Direct & General Support Maintenance for Generator Assemblies (2920-909-2483) Prestolite Model AMA-510UT
Direct & General Support Repair Parts for the Generator Assemblies (2920-909-2483) Prestolite Model AMA-510UT
Direct & General Support Maintenance (Including Repair Parts) for Generator Assemblies (2920-903-9534) Prestolite Model GHA4804JUT and the (2920-737-4750) Prestolite Model GHA-4802UT
Guyfang
28,630
Engine Components
TM 9-1826C
Ordnance Maintenance of the Carburators & Govenors, (Holley), Engine, (GMC Model 302) for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
TM 9-1826D
Ordnance Maintenance of the Carburators & Govenors, (Zenith), Engine, (GMC Model 302) for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Guyfang
28,630
Truck Components
TM 8601
Ordnance Maintenance of the Power Brake Equipment (Midland Steel) for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
Guyfang
28,630
Technical Bulletins
TB 9-2855-17 dated 1953
Instructions for Installation of Hard-Top Kit for 2 1/2 Ton, 6X6 Cargo Truck M135, (GMC 24V) SNL G-749
TB 9-2855-40 dated 1956
Instructions for Installation of Personal Heater Kit for the 2 1/2 Ton Cargo Trucks M135 & M211, Dump Truck M215, Gasoline Tank Truck M217, Shop Van Truck M220, Truck, Tractor M221 & Water Tank Truck M222
