ID 400 Gallon M149A Stainless Steel Water Tank Trailer W/ Many Upgrades
Road Warrior 88
-2
Grangeville, Idaho
400 Gallon M149A Water Tank Trailer Stainless Steel Tank. Wheels have been sand blasted and repainted. Upgraded from 9.00-20 NDT tires to 10.00-20 highway tires. New ball valve at the back and a new spigot at the front. This is the later version of the water buffalo trailer with the stainless steel tank. All exterior fittings have been resealed.
The only defect is the top hatch cover spring loaded hold downs need to be replaced or you could just use an adjustable loop pad lock to secure it. The top hatch cover seal and hinges work perfectly. $2,000
