The transmission control unit of my HMMWV gave the DTC 73 from the beginning.
The resistance measurement of the solenoid valve directly on the plug of the control unit was fine. So I bought a used, supposedly working control unit on ebay.
Unfortunately, this also gave the same DTC.
So I opened the control unit and discovered an obviously discolored Infineon power switch IC.
After replacing the IC, the control unit works again without any problems.
I would like to share this information because I think this is probably a common problem.
The spare part number is "TLE6220 GP".
