ABQIRONPIG IS BACK IN THE HOUSE!
ABQIRONPIG
AUSTIN
Damn, it’s been a while, 2012 I think….since then I’ve traveled to SA in a built 100 Series, traded it in Otavalo Ecuador for a 78 Unimog Doka overlander and went to Northern Patagonia and back. Then we went from Cartagena to Vera Cruz across to Mazatlan to La Paz in over 18 months.
Now we’re going from Sherman Texas to Dead Horse, AK in our new 98 LMTV and need some advice on battery tenders. I just dropped $900 on 4 new 6T batteries and need to maintain them. I’ve been lurking and reading the NOCO G7200 among others, charging thru the NATO port VS each individual battery, etc…
Who or where do I find CLIFFNOTES on the best set up?
btw, here’s Mildred…she’s been reset by RED RIVER ARSENAL in 2011 and is basically new with 800 miles.
NDT
7,930
Camp Wood/LC, TX
The consensus here is to use two group 31 batteries and put a 12 volt maintainer on each one, either a NOCO or Batteryminder.
Hope you read up on all the predictive maintenance tasks you MUST do to avoid countless unavoidable powertrain problems.
ABQIRONPIG
AUSTIN
No, but I’d really, really love to know where to find said material(s)
NDT
7,930
Camp Wood/LC, TX
Some suggestions for using the Steelsoldiers website. First of all, I recommend you post all FMTV related questions in the FMTV forum, so the FMTV contributors will see your questions and respond. Also, it may take a few days for people to see your post, so if you need rapid answers, it can be helpful to do searches within the FMTV forum using keywords like "maintainer" or "driveshaft" or "balance". Every imaginable problem and topic for these trucks has been covered multiple times. Lots of how-to's on Youtube as well.
DeMilitarized
1,219
Gainesville, GA
So I need to charge all 4 separately? Do I need
to unhook them?
I was really looking into using the NATO plug to charge all 4
Your expensive batteries will last the longest with a noco 4 battery charger. Built in 4 charging ports linked below. This will balance all of your batteries to the proper 12.8ish volts. You CAN plug into the nato slave port but your batteries will become imbalanced because of the 12/24v system on the FMTVs. Charging on the 24v slave plug WILL further imbalance your batteries and eventually lead to 12v battery bank failure.
Craiginct
Ct
before I started install the truck got 4 new batteries and was running fine 3 days before .
I installed the 10x4 yesterday and this morning two of the banks were cycling between 12v, red check mark ,and power light.
the two batteries in question where bt1 and bt2 after shutting down one of the banks the other one started working fine and after a while went green . So I tuned that bank off and tuned the other back on. Again after a while it to went green .
the remaining two banks on the charger where always green .
truck still not starting !
