I've got an issue with the cab tilt/spare tire/suspension mechanism that I can't find good guidance on in the TMs (TM 209-2320-365-20-2 is where I was looking). The backup manual pump works to raise/lower the cab and spare tire, however when I push in the PUMP button on the manifold nothing happens for any of the functions. I don't hear the pump going, and obviously nothing moves. Pushing it does, as far as I can tell, absolutely nothing. I should have good pressure as the cab air bags inflate/deflate and both pressure gauges in the dash are over 100 PSI. This happens with the truck running or off.
Not sure where to start here. One of the steps involves checking for 2,500-4,000PSI at one of the hoses but I don't have tooling to do that.
Any tips/advice on where to start?
