Auxilary fuel pump force on
dutchofsc
Sc
I have an 803a, I want to force the auxiliary fuel pump ON, even when the float switch is satisfied. I want to wire in a switch to make the aux pump turn on, to top off the fuel tank manually before storage, or to empty the long aux fuel hose when finished with it.
I've tried looking at the schematics, way over my head.
What wires do I need to supply power to, to force the fuel pump on, even when the float switch is satisfied? Are those wires behind the gage panel by chance? Hoping aimed smart electrical people can help, thanks.
Scoobyshep
2,647
Florida
You can either wire a bypass switch to float 2 or go straight to the aux pump E1 and apply power there. If it were me, id go straight to the fuel pump. Keep in mind that forcing this on can cause an overflow, So use with care. I dont think this mod can be done in the control cube, Im fairly sure that the float module (A9) is in the box (admittedly my 803 hands on time has been minimal, 003 i can tell you in my sleep) .
kloppk
4,343
NC
I'd suggest connecting your toggle switch across the FL2 float switch and not do it by providing power directly to the Aux Pump. Providing power directly to the pump will backfeed into the A9 possibly damaging it.
Wiring to the FL2 circuit would require removing the end panel covering the fuel tank.
dutchofsc
Sc
Great point, I don't want to back feed and damage anything
I'll get the panel removed and see what the best course of action is, I'd prefer to not have to cut up the original wiring. Any recommendations?
Soon I'd like to get the remote start from you, maybe Santa will bring me one
dutchofsc
Sc
Great point, I've spilled enough diesel in my life, don't need to spill any more. I might put the momentary switch near the fill, so I can actually see the fuel rising in the neck.
kloppk
4,343
NC
The connection between the A9 and the float switch is done with a 4 pin Molex connector.
To do the mod without cutting any wire could be done by building a little adapter like with a male and female Molex connector to tap into the FL2 circuit.
Something like this...
dutchofsc
Sc
Great idea and great advice, thank you both.
Can someone share links to where to buy the plugs and pins? I'd like to get this done this week.
kloppk
4,343
NC
Housing and pins one end
Molex Housing P/N 3092042 DigiKey Housing
Molex pins P/N 2092103 DigiKey Male Pins
Housing and Pins other end
Molex Housing P/N 3091042 DigiKey Molex Housing
Molex Pins P/N 2091104 DigiKey Molex Pins
Pins can be soldered onto the ends of your wires and snapped into the housings.
I've used Molex connectors a lot.
Let me know when you want Santa to load your Remote Start system on his sleigh 🎅
dutchofsc
Sc
Parts came in yesterday, got everything installed today. Went pretty smooth despite not having the correct crimping tools.
I tucked the switch up high near the aux hose, it's out of the way, out of the weather and clear of the hose. I decided to go with a toggle switch vs a momentary push button because the flow rate is sooooo slow, I did not want to held a button for 10 minutes.
I like the extension idea, wish I knew about it before dropping the order. It was 10 bucks shipped and I bought enough to make 2, just in case.
