Brake fluid change
LuckyWolf
125
33
Plymouth, England
Hi everyone,
I’ve been told by a fellow Deuce owner that it’s better to change the Dot 5 brake fluid to DOT4 as it’s safer, better all round and a lot cheaper,
can anyone confirm this?
thanks
Karl
21,236
Hi everyone,
thanks
Karl
You don't need to change the brake fluid. Just need to maintain whatever type of fluid (DOT3, DOT4, or DOT5 - Pick one and stick to it).
  • Like
Reactions: HDN
87cr250r
2,252
Rodeo, Ca
Properly, systems running DOT 5 fluids should have a bottom drain on the calipers. Without it, water can't be purged. Trucks like the CUCV have chrome plated caliper bores. Without that, seized pistons would be common. DOT 3/4/5.1 fluids a miscible with water which enables it to be flushed out through top vents. If you've got the $$$ there are silicone oils with higher specific gravity than water that would also allow water to be flushed out the vents.
