Cunmins 931a2 harmonic Balancer replacement
Jericho
72
Landaff NH
Iam off station from home. Harmonic balancer outer shell with the serpentine belt grooves seems to be slipping forward from the crank portion. Shredded my belt.
anyone have a good Cummins , Napa. Orieleys part number for a replacement. ?
are all 6cta Cummins balancers the same ? Thanks in advance. Stopped until I can fix it Andy
WillWagner
3,364
Monrovia, Ca.
Not all are the same. Some have larger OD and belt area OD. There should be a part number dot matrix stamped into yours.
Jericho
72
Landaff NH
Thanks Will. Good to know. I’ve been MIA for a few years. Glad to see you are still there and as always. Quick to reply and a good source of info. Again thank you sir. !
