- 239
- 8
- 18
- Suffolk VA
M925A2. No rusted thru spots, minor surface rust all over. Cab was replaced by stripped, painted, and undercoated cab from donor truck. Some pitting in bed from sitting, but was also stripped and painted. Pros: Two spring seats, fiberglass troop seats, new batteries relocated to right side toolbox, new blower motor,comes with wheel nut sockets. Cons: Slightly leaky rear tire (but have unmounted replacement), Small air leak on brake application (doesn't bleed truck air quickly), T-case interlock button inop. ( have to bleed off truck air to shift high/low).
An altogether decent truck that you can drive home. I've never done much with so it mostly sits. A recent seal change in the t-case convinced me that I don't want work on it anymore. Engine and drive train run strong. I'd rather see it go to a good home than keep sitting idle. Located in Suffolk, VA.
$15,000.00
![0427221153_HDR[1].jpg 0427221153_HDR[1].jpg](https://www.steelsoldiers.com/data/attachments/716/716323-4844fa64d4cd360d9b602d1fca602a29.jpg)
Add to the pros: H4 headlight conversion, snatch block comes with it.
$15,000.00
