hellpounder
- 40
- 18
- Indiana
[1986 M934A1]
I've been trying to engage the front axle, but it doesn't appear to be working. The switch on the dash will flip once I've built up to 90psi, light will come on, but nothing else happens. Switching to low range doesn't do anything either. After investigating, I see where two yellow lines that went to the valve with the actuator have been cut and capped, and there is a third black line that goes from the valve to the back of the transfercase.
Someone told me I could bypass this by capping the line that has constant air pressure and connecting the other two lines from the valve together, then I should be able to just flip the switch on the dash at will, regardless of high or low range. After testing, the middle yellow line held constant pressure, the right yellow line and the left black line did not, so I connected them, built up pressure to 90psi, and still no engagement. I can hear blowoff occuring at the switch when I flip it off, but nothing happens besides the light coming on.
I tested, and the front driveshaft does spin when going in forward and reverse, regardless of if the switch is on or not.
I'm still new to these, I've only had it a couple weeks, and haven't found much more pertinent information besides the clutch possibly being broken. It's supposed again the end of next week, and this is my only winter vehicle at the moment, so I'm trying to be as prepared for that as I can.
Also, what are signs that it is working correctly? Sounds, feelings when I flip the switch, etc.
