Gasket for MEP 003 fuel canister.
rickf
2,530
Pemberton, N.J.
I am sure this is listed somewhere in here but I need to try to get this today before the next cold spell hits tonight. It turns out that what I thought was a leaking tank is actually the center filter can gasket at the top. I will eventually change these filters to a more modern setup but this machine has 8 hours on it so I am not in a hurry to do that. I am in a hurry to stop the leak. I have a pan under it for now. I have not checked it with the pumps running but I would assume it is leaking pretty good then, right now it is just gravity feeding from the tank.
FarmingSmallKubota
1,464
Wapakoneta, Ohio
They are all over the place, just and oring
most new filter elements probably come with one
Filter is Fram C1125pl or Napa 3113
FYI you should always have an extra set of filters and basic maintenance parts on the shelf Good luck
