Generator Trailer Manuals
LuckeyD
774
Vilseck, Germany
The attached are the trailer chassis manuals used with all the TQG and AMMPS generators. A gen set sitting on a trailer usually has a data plate from DEPOT stating it is Power Unit or a Power Plant of some kind. The DEPOT only uses the chassis with suspension and axle with the hitch, and lighting. The rest is mounted at DEPOT. To have the correct manual set, one must have the generator manual, the PU or PP set manual, and the trailer chassis manual. All this information is found on Data Plates mounted on the towing bars. I found some things in old manuals do not get into the new manuals so hang on to the older manuals. I kept them separate because many trailers are used with different size generators and it saved memory space instead if having the same manual in 10 places,
LuckeyD
774
Vilseck, Germany
The information below was published until the info was incorporated into new manuals which in 2022 were not published yet. The PS magazine article has a good use as it gives the tire size that comes on wheel /tire assemblies.
