Stevnels17
- 1
- 3
- Ishpeming Michigan
Hello! I recently acquired a 1980’s ground heater H1, with a single cylinder Lister Petter engine. It was burning fine until the temperature went crazy and got to almost 400 degrees F. Now it won’t relight, the igniter is working I can see that, but there’s no fuel being introduced. I would guess it tripped a safety? but I’m not sure how those valves work, with the capillary tubes that run from the outlet air and to the bottom of the heat control valve and the temperature valve. Any help is very much appreciated as I can’t find much about this heater! Thank you again!!
