LMTV brake control valves
Bill Pfeiffer
Greenville FL
Hi folks, my fire department has a '97 LMTV converted to a brush truck and both of the dash mounted brake control valves are leaking up through the shaft seal. What is a good, inexpensive source for replacements? Thanks!
MugOfPaul
33
Portland, OR
First one I bought from this seller had a weird defect (leak at the casting seam) and he promptly refunded. Second one I got from him was perfect.
GeneralDisorder
6,525
Portland, OR
What Paul posted above but being a '97 you will have to build an adapter plate for the new style combo valve or find the older individual valves to replace what was used on the old A0 trucks like yours. And the plumbing is a little different if you adapt. Just label your lines and trace things carefully.
Bill Pfeiffer
Greenville FL
Thanks, but the lmtv uses 2 separate valves that mount to holes on a dash panel. I'm looking for the direct replacement...
GeneralDisorder
6,525
Portland, OR
Fundamentally no it works the same. It just eliminates the lines that connect the two valves together since those are now internal to the manifold they are both a part of. In addition you can delete the bulkhead vent line in favor of a sintered brass exhaust filter as was done on the A1R FMTV.
hike
—realizing each day
983
Texas Hill Country
If I recall correctly the new dual unit requires a new/revised mount plate: the holes are spaced differently?
Our local Napa had the old versions when we replaced ours—
GeneralDisorder
6,525
Portland, OR
You can just modify the plate. Basically cut out a rectangle and drill four holes. Trivial.
The modern component is now typically about $50 surplus on the usual marketplaces. Worth it to upgrade IMO. Now much more common - used on almost everything with air brakes.
