M1008 electrical question
ultim8gamr
Napa Valley, CA
I recently bought a M1008 and have noticed a few things. When the truck is running a popping sound can be heard every few minutes or so. I have noticed that when the pop is hear, the headlights dim slightly and then go brighter. is this something thats normal? and what is causing this? Does anyone know how the military is on maintaining kingpins on the D60 up front? the truck has a bad case of death wobble after it hits bumps at 35MPH. suspension shop in town said its most likely the tires, but everyone over at Pirate4x4 is saying the kingpins should be rebuilt.
John
mangus580
284
Western NY
The popping you are hearing, does it go away after a few minutes of running? I suspect you are hearing hte glow plugs cycle.
ultim8gamr
Napa Valley, CA
I thought that's what it might be, but i i'm pretty sure it continues even after a while. I had it idling in the driveway earlier this week to check fluids for 15 minutes or so and the sound continued the whole time. i haven't driven it in a week becuase it had the wrong pass side alternator so one is in the mail and I have only driven maybe 30mins at a time max on short trips in town b/c of the "death wobble" issue and i only bought it 2 weeks ago. Alternator should be coming in next monday along with new tires later that week so i should be able to get some more engine run time. Is there anything else that could be causing this noise?
JOhn
jumpmasterjim
NY/NJ
You could check the tie rods end. My buddys' 1008 had the death wobble. brought it to a shop. They said all was good. We checked again and found both tie rod ends were toast. Cost us about 200 for new ones.
ultim8gamr
Napa Valley, CA
my dad heard it and said that it sounds like a relay. any relays under the dash/ in that area that would or should not be making that noise.
as for DW, the suspension shop did say the drag link was bad, but i dont know if that affects DW
John
acetomatoco
10
The glow plug relay on the engine bay firewall about top dead center will cycle off and on based on signal from the glo plug card and the heat sensor in the intake manifold..remove the small light blue wire and see if the noise stops... ACE
acetomatoco
10
I had to do the tie rod ends on my M1008 at 30000... crummy GM stuff... one of them is very expensive....ACE
CCATLETT1984
Saint Clair Shores, MI
Re: RE: M1008 electrical question
The one side is only expensive because, in there infinite wisdom they made it part of the actual tie-rod instead of a replacable end. you would be better to get a beefier tie-rod at that point if you plan to do offroading. you can get a "rockrod" for ~$150 as i recall.
MaximumBob
I've just started working on my M1008 - driver's side alternator is bad - haven't checked the passenger side yet. Check the local auto parts stores and they can't even order the alternator. Can I ask where you ordered yours and how much it cost. Also, in your search did you see any alternator rebuild kits?
Thanks,
MaximumBob
ultim8gamr
Napa Valley, CA
I got the pass alternator at NAPA auto parts, they have saved me a few times now trying to find parts for this truck.. The previous owner put a drivers side alternator (no isolated ground) on the pass side so now i have a backup if the drivers side goes bad :mrgreen: The parts number for the pass side alternator with the isolated ground is the Wilson 90-01-4277 and it totaled $258 including shipping and without the core. it had to be shipped from Idaho (guess they're not too popular). i think the 100amp alternator without isolated ground is a bit less than the one with the isolated ground. http://www.steelsoldiers.com/Project 5.htm is a rebuild link my dad and I found while working out the alternator problems. Hope it helps.
John
MaximumBob
Perfect - exactly what I was looking for ... haven't tried NAPA yet - tried Pep Boys and Advanced Auto - NAPA is right down the street. I'll try them today. Thanks again.
Bob
gasser
Ocean Springs, MS
I would just go get yours rebuilt from a local shop; would cost you about $100 each and you would know that you have the right ones. Also, how did you know that the alternator is bad? Does your #2 Gen light come on when you put the Key into the Run position? If it doesn't, chances are your Alt is good and the dummy light is bad. Remember, the two dummy lights are in the charging circuit, so if these two lights are blown and/or the holdster isn't making a good connection, your alternators won't charge.
HTH,
-graham
MaximumBob
RE: Re: RE: M1008 electrical question
I actually pulled the alternator and tested it at two local auto parts stores - it's only putting out 11.7 volts. Unfortunately, I'm missing my instrument cluster and was hoping to start the truck without it - I've read that the alternators won't charge if the dummy lights [aka the whole instrument panel!] is missing. Are you sure this is the case with the M1008? Related, is there a workaround? - i.e. could I hard wire a bulb in the circuit? The big multiconnector is sticking out through the hole in the dash - I'm sure that I could locate the pinout somewhere.
Any thoughts would be appreciated.
gasser
Ocean Springs, MS
Re: RE: Re: RE: M1008 electrical question
MaximumBob said:
... I've read that the alternators won't charge if the dummy lights [aka the whole instrument panel!] is missing. Are you sure this is the case with the M1008? ...
Trying not to sound cocky, but I am 100% sure. I know this from personal experience. If your bulbs are not completing the circuit, the alts will not charge their respective batteries.
The only work around that I know is to locate the wires (that feed into the dash ribbon) and complete the circruits with gauges; however if you don't care about the individual circuits just put in a fuseable link in it's place and use the 28v gauge.
I don't know yet those wires are yet; i finally got my bulb holdsters to stay in there good, so at this moment (knocking on wood ....) it's charging. However, if I wiggle them or remove the bulbs, the 28v gauge drops into the between yellow/red or totally red.
HTH,
-graham
ultim8gamr
Napa Valley, CA
RE: Re: RE: Re: RE: M1008 electrical question
I've noticed that the lights will dim when the relay clicks, when i install a stereo to the 12v acc source in the fuse box will i notice any volume difference when this happens? and its kinda odd, but when i let the truck sit and idle every morning to warm up it doesnt seem to do enable (do the pop of) the glow plug relay until i drive it. maybe its that im not noticing it in the time that it takes me to walk out to it, get in and drive off. I usually let it sit 3-5 minutes. Why is this?
John
MaximumBob
Graham,
That's the confirmation I was looking for - I read the "missing light thing" somewhere, but to be honest, it sounds like such a poor design that I didn't believe it!
I'm in the midst of trying to locate an instrument panel (ideally with good light bulbs) which will take care of the problem!
Thanks again,
Bob
mangus580
284
Western NY
Re: RE: Re: RE: Re: RE: M1008 electrical question
MaximumBob said:
Graham,
Thanks again,
Bob
I was pretty sure I mentioned it in another thread where the question was asked specifically about the gauge panel. I had said this, based on helping Graham diagnose his problem...
Oh well!
You shouldn't, and also, this relay should only be doing this for a few minutes after running. I suspect that your controller is shot, if it continues for more than 3 minutes or so.
