mynewtoy
- 3
- 8
- West Pittson Pa.
Can anyone with a M1028A2 take a weld to weld measurement of there front drive shaft? It has to have the NP205 and be the dually at stock Height.
Thanks in advance.
Thanks in advance.
I concur. There are many different lengths of slip/stub yokes. If yours is different than the guy that checks his, you might be wasting your money. If you want it done right, measure ujoint center to flat flange and take it to a driveline shop for adjustment.A yoke to yoke measurement would be better.
Thanks for your help. Stonepicker1 that is the measurement I wanted but I also see what the others are saying . Is there a chance you can measure from center of the u-joint to the center of u-joint [where the front shaft bolts to the transfer case there are 2 joints if you don't mind just measure from the front joint at the diff to the joint right after the rear weld not the second joint closest to the rear flange that bolts to the transfer case] Hope I didn't cofuse you.
Thanks for your help Much appreciated!!
