IronGiant5Ton
- 26
- 13
- Connecticut
Good Afternoon Gents,
Task: Hook up an air compressor to an m923 so kids can honk the horn at touch a truck event without running the engine.
I have combed steel soldiers and reviewed fold outs for the air system on an m923a2.
It looks like the best way to do this is to put a QD on the front service air connection under the bumper. From the air diagram it looks like it leads back to the wet tank with no check valves inhibiting pressurization of the wet tank.
The other option is to remove a vent valve from the passenger side between the tool boxes and replace with a ball valve and QD.
Request ya'lls input for the best way to do this or if you have done this before? Thank you guys.
V/r
Max
U.S.N. Ret.
V/r
Max
U.S.N. Ret.
