maxspeed3
- 0
- 6
- Burnsville, Minnesota
So its finally starting. This Friday will mark the 1st official day that I have actually had time to start working on the deuce this spring. The list of to-do's keeps on growing and growing.
The first task on the list is to give her a fresh oil change and fuel filter change. Then the real fun will begin! I'm going to be sandblasting and repainting the truck over the next several weeks. The process that I've chosen to repaint the truck will take time, but in the end she is going to look excellent (I hope....) So after researching this forum and YouTube I came across another member here that used a pressure washer and an attachment for media blasting. (I'll search around for him on the forum)
But anyway he also posted a video of himself pressure washing the paint right off his wheels on this deuce and it worked perfect! @Heath_h49008 (I believe this was you...)
Here is what I'm going to be using:
Generac Pressure Washer 3000psi 2.8 gpm
This attachment from Northern Tool: http://www.northerntool.com/shop/tools/product_8520_8520
And lots of media
After blasting I'll be spraying primer then paint. I'm going to go with BEHR Exterior House Paint since its sprays nice and the paint as good quality (have been using this stuff for along time) .
The last thing I will be replacing are all of the wood pieces on the troop seats with Natural Cedar 1"x4" and staining them a natural wood color. Once this portion gets under way I'm going to create an AutoCAD File of all of the dimensions and amount of hardware that is needed to re-build these seats. Somewhat like a set of construction drawings. I'll post these drawings on this thread as a .pdf so anyone can open them up to use them to rebuild their seats.
Finally during my build I'll be taking hundreds of not thousands of photos documenting my process along the way, so I can have an album to show where the truck was when I started and where it is when I finish her up.
I'll try to update the thread as often as I can with photos and some journal entry's along the way!!
So sit down and crack open a cold one!
If anyone has any suggestions please leave me a message!
Thanks!
Maxspeed3- (Justin)
And lots of media
Thanks!
Maxspeed3- (Justin)
