Remote Start Controller Kit with ATS Control Card Bundle
For use in MEP-802A, MEP-803A, MEP-804A/B, MEP-805A, MEP-806A Generators
Wi-Fi Remote Control & 2-Wire Start/Stop
Remote Start Features include:
- 2-Wire Remote Start/Stop interface for use with ATS, Solar Charge Controller, or even a toggle switch.
- Remote Start/Stop via WIFI using a cell phone, laptop, tablet, etc. Anything with WiFi and a browser!
- Direct Wi-Fi communication. No router needed. Works during power failures.
- Hundreds of systems currently in use across the USA and around the globe
- Browser display of all engine and generator operating parameters on remote WIFI device. Parameters nearing extremes are highlighted in red text.
--> Ambient Temperature
--> Battery Voltage
--> AC Voltage
--> AC Output Frequency
--> %Load
--> Fuel Level
--> Coolant Temperature
--> Oil Pressure
- Remotely Enable and Disable the Auxiliary Fuel Pump
- Remote control of the Contactor with the Contactor state displayed
- User calibration of all parameters
- Data Logging of all parameters as well as engine hours and Start/Stop count. Min, Average & Max values logged every 10 seconds.
- Transfer between WIFI and Manual control while running
- Automatic Pre-Heat below 40 degrees F
- User programmable durations and delays for all phases of start up and shutdown. Separate settings for WiFi Start/Stop and 2 Wire Start/Stop
--> Pre-Heat duration
--> Fuel System prime duration
--> Cranking duration
--> Warm up
--> Stop command to contactor open delay
--> Cool down delay
- Antenna and connector are IP65 rated for water resistance.
- Retains full manual control of the generator thru it's front panel
- Controller is conformally coated to prevent corrosion
- Wire harness utilizes Mil Spec Air Frame wire rated to 300 F
- Includes Controller, wire harness, antenna, drill template, Stainless Steel mounting hardware for installation & manual
ATS Control Card Features include:
- Designed for use with low cost Generac RXSW & RXSC 100, 150 & 200 amp Automatic Transfer Switch's.
- Utility power monitoring to detect power loss
- Automatically starts the MEP-802A or MEP803A and causes the ATS to switch to generator power.
- Upon utility power restoration the ATS with switch back to utility power and the MEP generator will shut down.
- Selectable delay to prevent false generator starting due to brief utility outage
- Selectable delay to prevent false generator stopping due to brief utility power restoration
- Includes wire harness & installation and users manuals
Once built each system is tested in a generator simulator with a ATS connected. Additionally the Remote Start is tested and initially calibrated to assure a defect free unit.
Customer phone support provided to assist with installation.
Ordering Information
Cost: $900 PayPal, Venmo, Credit Cards & Checks accepted.
Includes USPS Priority Shipping
To order PM me.
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
Feel free to PM me with any questions!
Remote Start & ATS card pair
Supplied Remote Start Wire Harness
Remote Start Manual (802/803 shown) & supplied installation hardware
Supplied ATS Card Wire Harness
Wiring diagram for connection to Generac ATS
