I tried to explain it. Precise sets were usually provided for only certain systems, support systems, and hospitals. Then TQGs came out and they still did not have them really accurate. Had every one just a bit off I worked on. That was several thousand 15-60KWs. Again the 400HZ systems were more accurate. The DMM is pretty close. About 25% of the 30-60KW B models are also not accurate. We were provided factory extender cables to adjust the back planes so we could get them accurate again. This way the screens say what a DMM would read. So set your TQG with a DMM, read what you have and then you know the setting.
Oh, try this one. Do you really believe you have 120VAC at 60Hz from the power company? Take measurements at different times of the day and see at a wall outlet. Your gen when adjusted will be similar, or even more steady. Here i am supposed to have 220VAC at 50 Hz. Nope. 217-230VAC time dependent, at 49-51 Hz grid compensation dependent. At 1:36AM I have 233VAC and 49.99 Hz in my kitchen. Station transformer is across the street in the church yard. It is fed 254,000 VAC under ground so no poles. I asked when the power folks were there. Check yours. In Maryland I had 58-61 Hz 1 mile from a central power station distribution station for industrial plants at 115 to 130VAC. The 240 swung from 225-245VAC. This is acting thru the transformer taking 15,200 off the line to two houses. There are peaking transformers to 440VAC, on MCM 2 lines to an industrial plant and at higher voltages the difference is not too much. Same results at the military installation I worked on. Sensitive buildings had compensation AC inputs. Helps to understand what you are actually using in your house and paying for. Interesting. This does not effect what the meter does so you pay for what you use.
thanks for the humor.
Yes, I see lots of folks obsessing about the power quality of their generators, without the perspective of having checked their grid power quality. Depending on where you live, and what else is on your particular distribution circuit the power quality can be all over the map. An electrician I know used to live a mile or so beyond a golf course (wells, and distribution pumps), that was a mile or so from a metal fabricating shop (heavy duty presses, welders, rotary hammers, punches, etc., but only M-F) The voltage at his place was all over the map, and then folks started adding home solar that started driving the voltage around even more, and adding extra harmonic distortion from the inverters. Finally the utility relented and added an automatic voltage regulator just beyond the metal shop, and another just beyond the golf course, and life, as far as the power instabilities, settled down. When my neighbor down the road here added a budget solar system, the grid THD just exploded, despite several transformers between us. Jeesh. I highly doubt that their inverters meet the FCC and grid requirements for quality.
I've lived in a number of places around the US, and elsewhere, and I haven't been fortunate enough to live in more than one or two places that had high quality grid power.
The power from my MEP-803A is better than what comes across my meter, and by better, I mean lower THD, better voltage regulation, and for our uses, nearly equivalent frequency stability, and that was after the utility removed a capacitor bank that was really pushing our distribution circuit around. I suspect that our distribution circuit would benefit from a couple of automatic voltage regulators, but the utility is pretty miserly about installing them because of the capital costs and also the ongoing replacement costs as they are a wear item.
All the best,
2PbFeet
