parttime
- 18
- 3
- North Mississippi
Im in North MS I picked up an MEP803A 2 years ago. It had 250 hours. I added fluids and new batteries. Everything worked as advertised. I have used it half dozen times for 2-6 hours over the past couple years without noticing any issues. Due to current ice storm in North MS I have had it running for 6 days straight. After first 24 hours I noticed a drop in oil pressure and the oil had increased way above full mark on stick.
I changed the oil and it was 2 quarts more than expected and more like diesel than oil. I have read about metering pumps leaking into crank case, or injectors being stuck open both of which can cause excess disel fuel in oil and staving the engine of needed lubrication.
Currently I am dumping the oil every 12-24 hours and refilling with rotella T4. Pressures are staying above 20PSI, the exhaust temps are front to back cylinders (150, 200, 250,250). I will need to continue for another week. My question is I dont have spare parts now, can the metering pumps be adjusted to normalise temps/fuel wash?
Does anyone else have real world knowledge of keeping this running for another week better than changing oil every day to eliminate the diesel washout? If the auxillary pump was stuck on and overflowed the tanks could this cause diesel in the oil?
Any real world emergent advise is appreciated. Thanks
