MEP-804A, MEP-804B, MEP-805A, MEP-806A Replacement A1 AC Voltage Regulator
Features include:
• Can be used regardless if factory Voltage Regulator was made by Libby or Technology Research Corporation (TRC)
• Replacement for your defective or missing Voltage Regulator... or to have a spare on hand!
• Does not use the existing T1 transformer, R1 or R16 resistor (no need to remove or replace them)
• Input and output fuse protection. Fuse's are easily replaced if ever needed.
• Works with or without the "Fuse Mod" (Fuse Mod is not needed with this regulator)
• Includes new pre-wired front panel R1 voltage adjustment potentiometer
• New mounting hardware, wire labels Zip ties & detailed instructions included for installation
• 1 year warranty
Easy Installation:
• Remove and label 12 wires from existing Voltage Regulator
• Remove existing Voltage Regulator
• Install new Voltage Regulator & reconnect the 12 wires.
• Remove existing voltage adjustment potentiometer from front panel.
• Install new pre-wired voltage adjust potentiometer in front panel.
• Connect four clearly labeled wires to four points behind the control panel.
• Install supplied Zip Ties to secure wiring.
Limitations
• Does not support parallel generator operation
• 60 Hz operation only
I personally assemble each of the Voltage Regulators. Once built each Voltage Regulator is adjusted and load tested in a MEP to assure a defect free unit.
· 1 year warranty
· Includes detailed installation instructions
Ordering Information
Cost: $280 PayPal, Venmo, Credit Cards & Checks accepted.
Includes USPS Priority Shipping
To order PM me.
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
Feel free to PM me with any questions!
