SSETRANSPORT
- 3
- 3
- Honolulu, Hawaii
I have an MEP-804A with a 50/60 15KW TRC Voltage Regulator that was running normally before the radiator leaked. I had the radiator fixed and reinstalled. When I went to start it, it’s giving me an under voltage fault light. I had found a previous post with the test sequence to check the TRC voltage regulator and found it to be no good according to the posted test procedure. Changed it out with a known working one and also replaced the KTK-3 fuse with a brand new one.
When I started it and tried to flip the AC CIRCUIT INTERUPTER switch to closed to turn on the 3 phase power, it doesn’t stay on. The frequency and voltage gauges jump when starting but that’s about it. Frequency gauge jumps and goes back to 48, voltage gauge goes to about 5.
When I hold the start switch in the start position, I can illuminate the AC Circuit Interupter and get the 3 phase power, but as soon as I let go and it goes back to the run position, the under voltage light comes on. Sorry for the long windedness but wanted to make sure I explain everything I came across first. Any help is very much appreciated. Thank you in advance!!
