- 325
- 420
- 63
- Geographical Center of Virginia
2006 MEP-805B 30KW 60Hz Military Diesel Generator
- 1831 Original Hours
- Fully Operational, needs nothing.
- Pintle Hitch Trailer Included
These units are highly durable, reliable, quiet and have low fuel consumption. Most people that have bought this model from me use it to power their homes or garages. These are rated at 30kw 24/7 use, only needing to stop every 250 hours for an oil change. You can easily get well over 20,000 hours of use before needing to rebuild. This unit been load tested. Good batteries. I've sold and serviced military generators for years.
This is a 120/208 3 phase generator. Yes, you can use it to power your house by drawing off 2 legs that will give you 120/208 single phase. Most all 240 electronics will run on 208. Using it in 120/208 single phase configuration will give you 22kw capability. No, you can not convert an 805B to single phase.
$7200
Price is OBO/TRADE
May ONLY consider trades for skid steer attachments and other military equipment/vehicles.
Yes I can load it on your trailer or in the back of your truck. I travel frequently East of the Mississippi and may be able to deliver
The 30kW TQG Generator Set, MEP-805B, is a fully enclosed, self-contained, skid-mounted, portable unit. It is equipped with controls, instruments, and accessories necessary for operation as single unit or in parallel with another unit of the same class and mode. The generator set includes a diesel engine, brushless generator, cooling system, excitation system, governing system, fuel system, 24 VDC starting system, DCS, and fault system. The generator set is designed to be used with any piece of equipment requiring a medium source of AC power and operates in a “Hot and Basic” climatic condition range of -25 ̊F to +120 ̊F. This generator set is mobile and requires forklift support.
Fuel Capacity (Gal):23
Fuel Consumption (GPH):2.60
Fuel Requirement: Diesel Or JP8
Dimensions: 80"-36"-55" 2,931 LBS
Voltage (Volts):120/208/416
Frequency (Hz): 50/60
Speed (RPM):1800
Phase: 3
Engine: John Deere 4 Cylinder Model: 4045TF151
Displacement: 239 in3 (3.9L)
NSN: 6115-01-461-9335
$7200
Price is OBO/TRADE
Speed (RPM):1800
Phase: 3
