MEP803A - Diagnosing a Voltage Regulator
scjarena
12
Houston, Texas
I have a MEP803A, 400 hrs. Its always worked good for me until few couple days ago, the voltage is low, erratic, and the voltage potentiometer knob doesn't affect it. Now when I start it again the frequency needle it jumping back and forth erratically. It has the fuse mod on the regulator, but not the varistor. I've looked thru the manuals and I'm having trouble finding a detailed method for testing the regulator. Any help would be appreciated.
Mark
Light in the Dark
7,271
MA
Mark
Are you going by measurements, or gauges, with your descriptions above? Is the engine speed changing as you notice the hertz changing?
scjarena
12
Houston, Texas
I went thru the tests for the voltage regulator in the -24 technical manual. The regulator passed the several voltage and resistance tests. When I run the unit, the frequency is staying steady for the most part at 60hz. The voltage is what varies consistently, like riding a sine wave. The voltage measured at the output terminals show this, which reflects the pulsing. Also I when I connect to my shop lighting and run the unit the lights fluctuate between dim and bright. All this is with the engine running smooth and steady.
Not sure where to go next. I see a test for the AM-VM transfer switch in the manual, whatever that is. Any ideas?
