NV4500 bellhousing for 6.2?
79Vette
174
Los Angeles/CA
I am looking into putting a TR4050 or NV4500 into my 1009, which currently has a SM465. The thread below has a great table of parts used, but its been a few years and the links are not working
The Advanced Adapters 712576 bellhousing from the table is this unit, but I can't tell from the photos if it has the large starter pocket or not. I tried buying a SBC bellhousing from advanced adapters when I did my SM465 swap and I couldn't get one that fit over the starter. Or maybe there's a 24V starter with a smaller nose that would fit in the regular SBC bellhousing?
I'm curious what bellhousing/starter combo folks on here are running with your NV4500 or TR4050. That's the last piece of the puzzle I need to figure out, and I'll hopefully be ready to dive into this in a couple months once I wrap up my current project car.
Skinny
559
Portsmouth, NH
Not sure about the TR4050 but since the 6.2 came with an NV4500 attached to it from GM at some point why not source one from car-part.com or a part out listing on marketplace.
I run into a lot of 90s heavy duty series trucks with junk 6.5s and many are manuals.
79Vette
174
Los Angeles/CA
My current bellhousing is bent, and I didn't notice when I installed it. I adjusted the circular runout with dowel pins, but the bellhousing isn't parallel to the block face. This has put a bunch of preload on the input shaft of my Ranger gear splitter and ruined the input shaft and mainshaft where the 2 come together. I've had the drivetrain in and out four times in the last 5 years chasing my tail with this problem (progressively increasing noise as the shafts and bearings destroyed themselves) before I finally figured it out, but it's too late and the shafts have been ruined.
Unfortunately, advanced adapters discontinued the ranger splitter shortly after I bought it (2018 or so) and parts are not available. I already have an overdrive manual transmission drivetrain that I really like (twin stick shifting is awesome!), but the whole setup has basically been ruined by using a bad bell housing. Since I can't fix the ranger there's not another good solution for keeping overdrive with my sm465, so I'm looking into a NV4500 or tr4050 swap.
With the amount of money either is going to cost, I'd prefer to go with a new known good bellhousing. I know to check parallelism as well as run-out now, but I'm really hesitant to go buy another used bellhousing and then just end up with problems where I have to buy a new one anyway. If I hadn't been so cheap and gone with a used one 6 years ago I'd still have a running truck today, but instead I'm looking at a 5-8k drivetrain swap (4500 or 4050, ORD Magnum doubler, new custom driveshafts, clutch and bellhousing, shifters...) and all my labor to install it
