oil plug on M35 air pack - how to remove?
1,831
If it's really stuck, might be a lost cause. You can remove the J shaped steel line and squirt it in there.
acetomatoco
10
Sometimes a little heat and a small pipe wrench or a big vise grip... do not try it until your air tanks are drained!! Remember the oil is special and called OHT... you can get it from Jatonka.
cranetruck
99
Meadows of Dan, Virginia
For the oil, I use pneumatic tool lube oil, it it squirted into the large air chamber of the airpak and mixes with the air to lubricate the valves in the control section of the unit.
For stuck pipe plugs, I have been successful with an impact wrench used with a tight fitting socket and with care.
dabtl
Denton, Texas
I got lubed today at Travel America. I brought along a bottle of the pneumatic tool lube oil for the air pack.
The guy had some minor trouble removing the plug, squirted in the lube and all is well.
I am glad I was casually reading along today or I might never have caught that item.
