Radio Power Cable
SturmTyger380
31
Easley SC
Does anyone have a picture of how the power cable goes though the cab wall and into the bed?
Right now, my cab just has the opening and if I put a wire in there it will just be loose. Maybe there are some holders that mount around that cab hole?
NDT
7,930
Camp Wood/LC, TX
There is a Cannon connector that bolts in there. Doesn’t the hole have 4 screw holes around it?
ab705
241
33
Maine
Mine has a two-piece circular bracket/retainer (one piece on each side of the rear wall of the cab). It's secured with four round-head screws and has the remains of a rubber grommet in it. I don't know if the rubber grommet is original or not. When I get around to restoring the cab, I'll replace the grommet...probably with a solid piece of rubber (no hole), since my M37 is no longer an M42. The M42 command kit had been removed long ago, and the truck was rebadged back to an M37 again. This is what it looks like on the inside:
Here's the other side of the bracket:
NDT
7,930
Camp Wood/LC, TX
Oh I was wrong, that is just a cable pass through. The rubber prevents the cable from getting cut by the sheet metal.
