Radio tray feet help
KKroger
338
KC MO
There were holes in the floor with threaded inserts you probably have filled with bedliner or someone did. but the offset feet are what you want.
TOBASH
4,175
Brooklyn, NY
1/16” sheet Aluminum (or cold roll steel sheet)
Alternatively Square (rectangular) tube Aluminum or steel (roughly 3/4” or 1” or 1&1/2”) and cut off the top leaving three sides. You need to measure the radio tray foot to see what size is necessary.
Vice
Drill
Vicegrips
Spray paint optional
DIY
Ten minutes to make both
IMHO
