Boathook36
- 2
- 3
- Pennsylvania
I recently bought a pair of Stewart Warner 10560 heaters. Mine are the 10560M24B1 type. This forum had the publication TM 9--25540-205-24&P that details a great deal of good information about the heater itself. The wiring diagrams are pretty lacking, however, and the control box itself is not detailed at all. The first heater I tried to start had no power to the blower or igniter because of a previous owner mixing up the wiring in the control box. I'll post pictures of my progress here. If anyone else has experience with these heaters I'd like to hear about it.
I'm especially curious to hear about the military application of them. It seems like this upright version of the unit with the integrated fuel tank above it was used in the interior of certain armored vehicles like the Bradley. As near as I can tell there was a HUMVEE 30K BTU version that's basically just my 60K BTU unit but just stuck in low range. Those seem to have mounted horizontally with their fuel pump and fuel filter separate. It seems like they might have been used in the 2.5 ton trucks but I can't tell if they were mounted underneath or if they used the upright unit like I have.
I was told that you should always start it in High range but don't see any mention of that in the documentation so far. I can see that the switch itself is a simple on off switch that is only energized when the light is on, which also indicates the flame sensor has closed, which also opens the power to the ignitor. As near as I can tell it doesn't matter what position the high low switch is in while starting it.
