I just went down the rabbit hole on the MTR research and got a pair of them after it was essentially understood as the problem with them being typical tire issues which are not cracked or split and not left outside for decades, theyll be fine. The recall was never "offficial" and was just from the local commands issues stemming from leaving them out and dry rotting which is like any tire.
That NOS A2 arm looks pretty had for 5k miles. Mine had 8k and its still tight. Guess it depends on variant (armor vs none, offroad vs onroad). Dont want to spend the coin to redo the entire steering system to house the moog from A2 model and theres tons of NOS components for cheap which id prefer over China/repro crap.
Really? Just what research did you do on the MTR debacle?
I know first hand entire fleets of Hmmwv’s were deadlined….ask me how I know.
The MTR issue was a piss poor design and mold, hence whey it’s no longer mfg’d and the tire of choice is the Baja BFG.
The Issue so happens to be that the tires were under inflated on UAH’s, the required PSI is 50-60 psi.
ive seen 20yr old MT’s with little to no sidewall cracking, ive got BFG’s on every truck I own and no side wall cracking, 97% of every truck received in has side wall failure if MTR equipped, I’ve currently got approximately 8 trucks here needing new tires.
as far as parts? You get what you pay for, I only use OEM parts from a distributor, that’s MAC and HPG, unless you can spot the
the difference, which most can’t, the key to parts application is using the proper TM and UOC.
And yes, I had a CAC card when this was an issue…your CAC doesn’t get you some unlimited amount of unseen data that a Civ can’t see on this issue…cuz if there was some level security classification on it? You couldn’t put it out anyway.
