trkosaur
- 0
- 1
- austin, tx
Hey Guys,
Have a question. I've put about 12k miles on my m1009 and everything has run fine. In the last week or two, it has developed the standard rough/late shift. It wants to shift out of first somewhere between 25-33, but 2nd is still fine.
On my truck, the regulator was already bypassed. So, I changed all the rubber hoses, put a newer, adjustable modulator on the trans and am still playing with it to get things right.
My question is, when I was vac testing the lines I got the same test at the vac pump and at the trans. So I don't think I have any leaks or clogs. However, the vacuum guage bounced furiously between 10-15. Does this bouncing possible indicate that my vac pump may be going bad?? It seems like everything I have read indicates a particular number, whereas mine was more of a "range".
Thanks for any help guys.
