turn signal/ marker light problem
firestomper
manahawkin new jersey
replace all of the original lights with new LED lights, also changed the flasher and turn signal switch. Before the change out all of the old style lights worked has they should. how that they have all been changed to LED turn signals do not work. any ideas on what I may have done wrong? Thanks in advance.
1,196
Some flasher units will not work with led lights.
TOBASH
4,173
Brooklyn, NY
From what I know:
You may need flasher relay(s) that accepts LEDs. Most flashers function once there is an electrical draw. LEDs use such a small amount of current that they are unable to activate a flasher relay.
What you need are flasher solenoids that are specifically made to turn on and off whether or not there is a current draw. In other words, you'll need flasher's that are made to work with LEDs.
Best,
T
EDIT - Post # 5 has the best answer
ryanruck
47
Cincinnati, OH
I see you said that you replaced the turn signal switch. Did you replace the bulb in the the switch with an LED bulb?
I know that with certain flashers, that's needed to get everything to operate correctly. It's a BA9S bulb.
I've got one of these in my switch indicator.
86humv
567
Texas
LED light test :
Tested the directional lights and found :
With all four Grote led's , and a incandescent light bulb in blinker switch : thermal switch made by Swiss controls [ 12418344 ],
Aurora Cord [ 11613631 ], and Riverside Mfg. [ 11613631 ] lights work as they should.
The Nartron 11613631 won't work, unless you change the 1819 incandescent bulb in the blinker switch with a 28 vdc LED bulb.
First pic is a Nartron
Second pic is others listed above.
dmetalmiki
2,071
London England
Unless you have sufficient resistance (at the 'bulb' end) you will not have them flashing. (remember?) when one flasher light bulb goes duff, and then I either nothing will flash, or on some vehicles the single remaining bulb front or rear flashes erratically. Replace the 'duff' bulb, and alls well again with a steady flash. So, as said you need a resistor in the circuits. And all will be well again. Actually some LED kits come supplied with resistors for just that reason.
VVFD
Vanderpool, Texas
Guys, I need a little assistance with a blinker problem. Searched a bunch of msgs and didn't see an answer.
We have '93 M988 with incandescent turn signal bulbs. Blinker will not work until truck has been driven enough to get warmed up.. then they seem to work most of the time until driven next. Took blinker switch apart and found gray wire on the spring contact board loose. It appeared to be a 'cold' solder joint; but on second thought it might have overheated enough to soften the solder up enough to pull loose. Re-soldered the wire and put the switch back into service. Checked, cleaned, and tightened cannon plug on the switch... also checked, cleaned, and tightened cannon plug into the blinker control box. Still have the same problem.
I'm suspecting the blinker control box is bad.
To change the blinker box, it appears there are two screws to get it out. With the blinker switch removed, I can get to the right side screw... I'm guessing that I need to remove the master light switch to get to the left screw. Anyone been through this that can give some pointers?
Also, does anyone know which blinker control box I need or do I need to pull the old one out to get a part number off the box?
VVFD
Vanderpool, Texas
Sorry 86humv, I re-read all the posts of 02/07/17 in this thread and did not find the info that I need help with. Must be somewhere between the lines of text that I can't see.
Beerslayer
55
Tualatin, Oregon
This:
And this:
Today sadly, search engine is not my friend. I searched the entire site using Google with this string:
led turn signal flasher site:steelsoldiers.com
And found lots of threads by people who didn't use search and asked the same question over and over,,,
I've got LED lights on my M923, put in the LED flasher unit with the fins 7 years ago and it worked fine for a few years. Now it doesn't work until the truck has been driven for a while. I don't see the answer in the thread above or anywhere else.
For someone with experience with this specific problem, is the flasher faulty? Hate buying expensive parts if I don't need them.
Already checked the grounds and other connections, obvious stuff.
Ideas?
Thanks!
VVFD
Vanderpool, Texas
This:
And this:
Ideas?
Thanks!
I to am interested to see some answers from the experts that have experienced and fixed this problem.
86m998
Groton, MA
I am having similar issues. 1986 M998 turn signals just stopped working & brake lights at same time. Confirmed all bulbs are good. Turn signals turn on but don't flash. Hazards switch does nothing; doesn't even turn them on solid. While diagnosing I notice brake lights will come on when pedal is depressed fully with significant pressure. I believe from other posts that the flashing module for turn signals if different than the one for turn signals so I think it's too coincidental that both would fail at same time. Any ideas?
Milcommoguy
2,463
Rosamond, CA
Not to sure what your trying to say. There is only one flasher unit or same for turning as for emergency hazards. Don't have a spare?? Quick check. It is a 3 wire device. One of the wires is ground = pin C, One is power, pin A and the other is interrupted - flashing output, pin B to a LAMPS / LOAD.
My quickie Flasher, Turn control switch & Service Lighting Switch Test>
Things to know:
Service Lighting Switch sends power to Turn Signal Switch.
Turn Signal Switch sends power to the Flasher when selected and does a lot of switching (hows that for an explanation) But in this case breaks the brake lighting and adds in the flasher for the left/right/hazard feature.
Here we go>>>
Get your VOM.
SERVICE LIGHTING SWITCH select to STOP LIGHT position (this switch MUST be working in ALL positions (not black out) and could be the beginning of problems.
This switch feeds power to all lighting and horn. With the goings on inside, can be a headache. If you can "honk" the horn in the STOP LIGHT position it will work for this test. DO NOT use the BLACK OUT position.
Can you honk the horn? GOOD
Is the Turn Signal SW mounted well and grounded?
Do the brake lights work? Push the peddle, GOOD (with or without connector to flasher) NO... bad Brake SW or Turn Signal SW or wiring.
Measure voltage at PIN B with switch above in STOP LIGHT and TURN SIGNAL SW in each of the left / right / hazard position. NO voltage? Bad Turn Signal SW or wiring.
Got voltage? NEXT
Connect a jumper wire from pins A to B on the 3 wire flasher pig tail connector above. (solid number 14ga house wire about 3 inches formed into a U and easy to do, poke it in A & B)
All lamps with a PROPERLY working turn signal control switch when selected left or right or hazard will light corresponding SOLID ON good lamps front and rear. If not BAD Turn Signal Sw. or wiring.
Backing up.... GOOD above ??? Check "PIG Tail" leads with VOM. PIN C to ground, a very low resistance 1 ohms or less.
Meeting all of the above, find a good flasher.
Don't over think it. There's a lot going on in these switches. Yes, you can shot-gun the whole process, But I like to narrow it down and know what's going on... divide and conqueror, process of elimination.
These tests should take less than the time to remove the rusty connector and find the A/B/C pins. first time a little longer, CAMO
Milcommoguy
2,463
Rosamond, CA
ME BAD... Re-read your post and know that battery feed is continuous thru the PCB or Protective Control Box, next on to a circuit breaker, then to the Lighting Selector Switch. There is a lot going on in that switch mechanically to make or break circuits as needed. Any connection (pin-plug-wire) linking these components can be a potential problem adding to the mix. It's is hard to diagnose electrical problem (especially intermittent) with magic results on thirty year old equipment over the internet... without jumping in and working forwards and sometime backwards to a successful repair.
And things can get really sideways over the internet. Good Luck, CAMO
Tjblanchard
Hers is one for you guys, M1151 Signals and stop lights work perfectly until i turn on tail lights. Once i turn on the tail lights the signal switch blinks but lights just get bright on the side i'm trying to signal. Would anyone have a clue which way to go with this.
21,242
I would start checking grounds in the lighting circuit
maxpower_365
15
Spokane, WA
I'm having a similar problem. I have a 2006 M1152. I have Trucklite LEDs for the back brake lights and I have Interlog LEDs for the front turn signals. When I'm just using the running lights (no headlights), the turn signal flasher seems to work with both the front and the back lights. When I turn on the headlights, the rear lights flash, but the front turn signals just get brighter on the side I'm signalling, but they don't flash. It seems really strange to me that the front turn signals flash fine when the headlights aren't on, but then they stop flashing when you turn the headlights on.
Any ideas?
Coug
4,974
Olympia/WA
Any ideas?
Sounds like you've got voltage bleeding over to the front turn signals. Could be a wire hooked up wrong or bad wiring somewhere. A bad ground connection can also cause voltage to go through more than one light assembly trying to find it's way to ground.
I'd start by double checking wire numbers on the headlights and turn signal assemblies, then start checking ground wire connections.
maxpower_365
15
Spokane, WA
Update on diagnosing this. If I disconnect the parking light lead the turn signals will now flash when the headlights are on. If I reconnect the parking light lead the turn signals ceases to flash when the headlights are on. I'm looking at the wiring diagram and I cannot fathom what could be causing the parking lights to prevent the signals from flashing when the headlights are on. The turn signals work fine when the headlights are off.
G744
4,391
Hidden Valley, Az
The ground return leads have to be hooked to a proven good ground.
As an example the front park/turn lamp has more than one circuit, all of them use a single ground.
It that is faulty, current will find it's way thru another light and cause weird operations.
A bit of corrosion or a loose bolt will do that.
A lot of tactical electrical systems weren't designed to run LED lighting.
Most of the problems with them stem from the LACK of current used by them, and any questionable connection manifests as the problem.
Personally, I don't see the attraction in converting them into the system. Lifespan over incandescent? Cool factor?
It's your vehicle, indeed.
G744
