MN USED Trailer Cable Wiring Harness
76Z5M
30
Circle Pines, MN
This is a USED/Take-Off front wiring harness/cable for use on most military trailers. One of the connectors that allow this harness to connect to the rest of the trailer wiring is missing. They are readily available through on-line dealers. Each wire has been tested and there is continuity through the cable, to the corresponding plug/terminal. Note that a conventional 4 wire civilian plug has been installed onto the cable, for use in operating the lights on a civilian boat trailer, or light utility trailer. This can easily be removed, for use on a military trailer. There is the normal wear and tear that would be expected on a used cable. Price: $40.00 plus shipping from 55014. Please respond to this ad, or call John at 612-709-5571.
