Went to see a nice M37, it has the dreaded death wobble
Don1357
Aurora Colorado
Near Denver. If somebody could suggest a mechanic to diagnose it would be helpful.
Everything looks great, it does leak oil here and there but nothing terrible nor puddling forming. I wanted to test cruising speed at 45mph but once it went past 40 the front just starting shaking left and right something fierce. And I mean, unbalanced washing machine on spin cycle sort of fierce. I brought the speed down, unclenched my bottom, and was able to bring the speed back up without most of the wobble, but later it came again just as fierce.
Best guess something is not tight and when the right vibration hits it, things go haywire.
[EDIT] Chatting to the current owner who doesn't drive it much and usually below 35mph, second guess is that it needs a front end alignment and wheel balancing.
As I said, I would like to take it to a mechanic to see what's what before I decide to buy it.
Don1357
Aurora Colorado
I briefly crawled underneath but could not spot anything amiss with the naked eye. Which honestly, it doesn't say much... These guys were gone by my army days but I recognize the overbuilt construction, I'm hoping that front end alignment/wheel balancing would cure it. If anything I'm sure they are not helping.
Follow up question: is there a transmission replacement that could fit in without modifications? The gearing jump between 3rd and 4th is significant.
wildcatter2009
Sask.
As previously stated, likely tie rod ends or loose king pin bearings. To check, have someone turn the steering wheel back and forth while you watch tie rod ends for looseness. For kingpins, jack up the front axle and grip the tire at top and bottom. Try to tip wheel in and out to check for looseness.
CA-Deplorable
47
California
Was the M37 by any chance the one located in Bennett, Colorado? I was also interested in an M37 in the Denver area. If it's the one we're talking about, it's going on an auction site at the end of March. I saw a video of the driver driving it, and if you look closely, you'll see him turn the steering wheel a couple of times before the front wheels start to react. The guy did a basic figure 8 in the vehicle with a reverse too. All the times he turns the steering wheel but the front end is slow to react. There was something definitely wrong with the front axle.
G744
4,390
Hidden Valley, Az
With all that said, it could be the following, not is any specific order:
Worn or misadjusted steering box.
Drag link wear.
Drag link pivot wear.
Front knuckle bearings loose (It doesn't have "king pins").
Tie rod end wear.
Toe out of spec.
Loose wheel bearings.
Spring wear causing improper caster.
Tires hopelessly out of balance.
None of the above are all that serious to fix.
G744
CA-Deplorable
47
California
Drag link wear.
Tie rod end wear.
Toe out of spec.
G744
It is viewable on the auction website. It's a good looking vehicle, very clean!
