rolling18
- 80
- 28
- Portland, OR
Thanks Juan.I cant seem to find this plastic buckle fastener part. Dont know what it's called, I tried a google image search and nothing.
my plastic fasteners have mostly all broken cargo cover strap fastener hook
what is this?
are they made in metal?
thanks!View attachment 961408
I just sent a PM!Commonly called an Anc
Thanks Juan.
@rolling18
They are commonly referred to as Ancra buckles. When they were originally made, they had a metal spring tab, which lasted a looooooong time. The current production uses that little plastic injection molded one piece tab.
I found a truck cover company that will make them in metal, at $25 each, minimum order in the hundreds... I didn't place an order.
Hummer Parts Guy sells the current production all-plastic ones for about the same price.
I have a small stash. They don't have straps on them, unlike HPG's. But if you're going to put them on existing straps it won't matter.
If you are interested I will check how many I have. Message me if you want to discuss.
Bulldogger
Original early era metal spring tab or the current mostly plastic ones?I have bags of them…used take offs
they are all mixed, I don’t sort them, I try to cut off only the functional onesOriginal early era metal spring tab or the current mostly plastic ones?
Bulldogger
Assuming you want to maintain the military look?They are commonly referred to as Ancra buckles.
