kenz5380
- 1
- 0
- Denver, CO
So a friend of mine picked up an exceptionally clean M1008 from Kansas last week. I've been working with him to try to get it running, but we are having some trouble. The truck turns over smoothly with new batteries. The glow plug system is working perfectly with new glow plugs and appropriate voltages at every point. It just won't fire up. We're getting some grey smoke out the tail pipe while cranking but no more than that. We've bled the fuel system from the tank all the way down to the injectors, and replaced the fuel filter.
Interestingly the truck came with a built in ether injection system controlled by a button on the dash. The truck is painted white so we thought maybe this was part of some sort of arctic package? I have never seen a built in ether injector before. We have not been using the ether as I know it is not the safest thing to do but obviously someone has.
We are going to do a compression test this afternoon and I will report on how that goes, but I have no reason to believe that there isn't good compression. The truck is at about 65k on the odometer. I suppose it could have been idled for long periods of time and has a lot of blow by?
Any ideas as to what the issue is would be greatly appreciated. I've searched the forum and can't find anything applicable. I've also gone through all of the suggestions in the TM troubleshooting guide with no luck. I'm thinking possible bad injectors?
Also, the timing marks appear to be lined up properly.
Thank you for your help.
