Jeepsinker
- 472
- 83
- Dry Creek, Louisiana
So I put my transfer case in neutral today to engage the pto for the crane on my truck to test everything that runs off of the rear pto. Everything worked fine until I tried to put the truck back into gear. It wants to stay I low gear or neutral. The shift lever was bottoming out on the floor and still not putting it into high range, so I adjusted the linkages under the truck all the way out so the lever doesn't hit the floor when I push it down hard, but still no luck, and the air switch on the linkage won't go back to the drive position either. Going to mess with it more tomorrow. Transfer case was replaced in 2011 and no miles on it since except by me. Any suggestions for tomorrow?
