jp-8 and wmo in 6.2.s military test
AECS
Munford, TN
Alot of talk about JP8, I have access to the navy version JP5, will that work as a cutting agent? Flash point is 140 which is higher then JP8. I am wanting to use it at about 60%WMO and 40 JP5. blend, settle and filter to 1 micron....
andy3
12
Suwanee, Ga
That ratio sounds about right.
Beyond Biodiesel
37
Prescott, AZ
I have been running 20% gasoline to 80 WVO for 7 years, and find it runs quite well. In the winter up to 30% runs better in the cold, but you have to keep in mind that you need to settle your blends for a few weeks, or run them through a centrifuge.
Keith_J
1,329
Schertz TX
Having a "fleet" of vehicles with four driving age boys and a wife, I have waste motor oil to dispose. Since none of the boys know how to drive back to the store to properly dispose of engine oil, I dump the used oil from certain vehicles into the tank of my 1031. Spark ignition engine oils (S class) in 5w30 should be fine as they are low deposit, low ash types with very low ZDDP.
So far, no issues after one tank, about two gallons to 15 of D2. Cannot say on fuel economy as it has been pulling a 4500 pound trailer in town traffic.
