- 10,881
- 832
- Appomattox, VA
There used to be a pile of 3/4-ton trailers at Colemans' Surplus that were antenna support trailers. They didn't have an extendable antenna in them that mounted and extended while in the trailer, it was merely a trailer that had lots of cabling, antenna masts, a small genset, and related radio gear bolted down in it for stowage. The trailer had all sorts of custom mounts for this gear, like it was an catalog item, not just a standard M101 trailer. There was also a gas tank mounted underneath the cargo body to hold gas for the genset in the bed.
Most if not all of these trailers were scrapped last time I was there.
Does anyone know which trailer model I am referring to? There were dozens of them, all modified in the same configuration, so it was a standard item not just a one-off.
