- 10,345
- 99
- 48
- Meadows of Dan, Virginia
And you should ALWAYS make sure the person riding shotgun is COMPENTENT.June 30th, 2015.
You might want to get used to not seeing your M105A2 trailer unless you are in a sharp turn, because otherwise, IF you do see the trailer, something's going really wrong with it. Normally, in daylight, if I see that shadow on the ground, I know where my trailer is at.
If you set you west coast mirrors so you can see what is beside your truck (without the convex fisheye mirrors), you have them set wrong and all you are going to see behind your truck is little or nothing...... The trick is to get used to monitoring your rearview mirrors and have an awareness of what's around you, because without the fisheye mirrors, any small vehicle that gets in the blind spot is apt to get run over... Most cops will not fault you if the mirrors are set right and the car driver did something typically stupid....
We had a 1960's Autocar tractor that because of the length and height of the engine hood, it was always well to have a rider on the passenger side as the blind spot was humongous to the right front side of the hood... Especially if used in a parade to haul a float, it was pretty much mandatory. Most deuces and most Unimogs in the military always had a co-driver to handle the right side of the truck for safety purposes and for backing up with trailers and also to loading docks.
To give you some frame of reference, if a locomotive (diesel) is running long hood front (engine end front), the blind spot beyond the hood end is better then 400' long if you have a fireman/conductor, more if you are running the engine with the other crewman on the ground (as in switching).
Be aware and be careful, and you will learn to handle the deuce with a trailer. At least you see the trailer (M105) better then towing an M105MM Howitzer....![]()
Everyone as far as I've seen have, covered all the bases! So the balls in your court! I did as some have said on small trailers add marker sticks on the trailers so I knew where they were at all times, we mounted them high and pointing up so as not to add to them hitting anything.And you should ALWAYS make sure the person riding shotgun is COMPENTENT.
