Phildoe
- 0
- 0
- Dundee Michigan
Ok so an update* Since the weather has been warmer the past day and its going to be warm the next few, i figured i would work on the wiring for the ignition of my old truck. Found that the wire labeled 12 or I runs directly from the ignition switch over to the coil and distributor system, (thanks to a fellow member here, Paul Euliss) My issue now is when i turn on the power and connect the hot wire i get a good spark from that wire, the wiring does not get hot or even warm and i am wondering if that's supposed to be like that?? I replaced the whole wire from the ignition switch to the distributor since that wire was cracked and could have been grounding out. I also replaced the whole ignition switch since the old one was split and had a cracked and rusted housing. Is the ignition power supposed to give off a good spark from the hot wire when connected and power is on??
