Secret for driving a BRDM-2?
kcimb
212
Fort Worth, Texas
Seems like ours is easy to get into first and harder to get into R but going from first to second is a bear. It starts quickly and it's a sweet vehicle, however.
Any pointers? Perhaps I'm not getting the double clutching down right?
Robin33ba07
37
Co. Meath ,Ireland
double clutch all the time maybe let the gearbox oil warm up a bit before driving off ,most or nearly all go a bit better is let warm up first (OT90 VT55 ) ?
colin455
Slave Lake, AB
I was looking into a BTR-60 yesterday and am sure they mentioned the transmission was meant to be pre-shifted into the next gear and depressing the clutch engaged the new gear while making a hissing noise like an air solenoid. I could be mistaken but distinctly remember thinking "how odd".
Perhaps research the BTR and see if it matches. Both are Soviet Bloc units.
Hope it was remotely helpful.
dmetalmiki
2,071
London England
Nope.. That is with the OT90, Which has an epicyclic gearbox, A sort'a copy of the daimler Pre-Selector gearbox.
The BTR60 has Two Petrol engines TWO gearboxes and ONE single Hydraulically operated clutch. And ARE a t..t to drive and change gear in. Remember that both engines have to be synced together.
The BTR 80 (I would love one!) was a better version with the single (Huge tough) V8 kamaz diesel engine in it.
Gear changing is best Always Double Clutching.
kcimb
212
Fort Worth, Texas
I've tried double clutching, it doesn't want to shift even then. It's almost like there's something wrong with the shifting mechanism and it won't go into gear. When I move the stick it hits a wall.
WarHorse_Alex
237
33
Russia
Hi. Is problem in shifting stay? Check hydraulic booster of clutch for leaks, hydraulic cylinder for air suck and check level of oil... And more - what is oil in system?
