Changing the tires on this was a long process... First, no tire company around here wanted to even touch this do to the beadlocks..Once I found a place to do it, It took them 45 minutes per rim to take off the tire..inside the rim is a huge rubber doughnut that was very hard to get out.. Putting it back together took them 30 minutes a rim.. The problem now is that it leaks at the beadlock ring.. The gasket looked good around the rim...Not sure where i can find a new gasket.. I might have to use some type of silicone.. Just thought i would share this...
