3 Jake heads under a stock M809 hood!!!
US6x4
2,591
Wenatchee, WA
Looks good.
Might have some trapped air or a sticky solenoid. You could swap solenoids and see if it follows it.
I watched my short video again and the #5 was pumping out air bubbles from the control valve drain so there is still trapped air in there. I have yet to rev up and then engage that brake - I've only been playing with it at idle so I'll bleed it some more this afternoon and see if I can purge the remaining air out.
Jakelc15
42
Hanover Pa
The air is no big deal. The oil will drain from them if the truck sits for a long period. I notice mine will come on a few seconds apart after sitting for a month or so. Then they work as normal.
I was having trouble with my throttle returning to idle and initially thought it was because of the jake switch. So I adjusted it a little. I was wrong, got some flames from the exhaust on a drive! Pedal shaft was sticking. Fixed now.
I'm not sure how loud the stock exhaust will be with them but mine is 104db in cab with the windows up!
Are you using 24v solenoids?
US6x4
2,591
Wenatchee, WA
I'm using 12v solenoids powered from a drop wire? from the 12 volt post.
US6x4
2,591
Wenatchee, WA
That's good to know. Do you tend to turn them on after sitting and get them primed so that they're ready when you really need them?
Jakelc15
42
Hanover Pa
I think I have a 12v solenoid around here somewhere if you want a spare.
I just pop it on at 2000 rpm to keep the rpm's in check. It comes right on. I tend to kick them on when I come up to a slow vehicle also. If your going slower than me then that's a problem!
US6x4
2,591
Wenatchee, WA
I would like to have a spare solenoid if you round one up sometime.
I was able to get the rest of the air purged out and now all 3 Jakes function as advertised :) All 3 valve covers are bolted on and I just need to reattach the draft tube, the filler cap chain, and the wiring brackets I made. I also need to finish the wiring from the firewall to the heads.
Lonnie
22
Pittsburgh, PA
If you have the opportunity to road test each Jake individually, could you confirm each sounds the same? My center jake is quieter & I cannot figure out why. I thought it may be due to the firing order or the proximity to the turbo... I'm just guessing but wouldn't mind a second opinion.
US6x4
2,591
Wenatchee, WA
If you have the opportunity to road test each Jake individually, could you confirn each sounds the same? My center jake is quieter & I cannot figure out why. I thought is may be due to the firing order or the proximity to the turbo... I'm just guessing but wouldnt mind a second opinion.
Actually, when bleeding them I noticed the center one sounded different than the front or rear (higher pitched). I figured it was to do with the firing order but with 1-5-3-6-2-4 it looks like the 1st head (1 & 2) have three cylinders firing between them, the 2nd head (3 & 4) have two cylinders between and the 3rd head (5 & 6) have one cylinder between them so each one should sound unique.
When my wiring is done I'll have the choice of front & rear or all 3 but I could experiment with unplugging some of them to isolate the center head alone. Naturally I would want to experiment up on snob hill at 4 A.M. ....
Lonnie
22
Pittsburgh, PA
My center one sounded more muffled similar to the pop from an air compressor, whereas the rear one had the more obnoxioius typical Jake brake sound.
US6x4
2,591
Wenatchee, WA
I took my Jake-equipped M813 out for a test run yesterday and it was sweet! The LO and HI work very well and it's not too loud with my H-161 headset on :)
My issue with the rear head not shutting off immediately has returned so I'm going to look at the inner springs on the control valves for cylinders 5&6. I was testing the throttle switch to shut off the brakes with the rear brake still fading out & got a good pop out of that! My other issue is the throttle wanted to rev the engine to a 1700 rpm idle so I'll need to check the throttle switch for interference and my pedal linkage for lubricity as @Jakelc15 suggested.
My daughter filmed a 15 minute bouncy video so once I figure out how edit out all the fluff I'll post the meat & potatoes portion for everyone.
Hammer
402
Winlock, WA
Why only High and Low? Why not medium to have two working?
I know in my M920, and other commercial semi tractor and wrecker trucks, I would use the different settings for different grades. Makes it nice to have a little more control,
US6x4
2,591
Wenatchee, WA
So on my setup LO is front and rear heads and HI is all 3 heads. Since I wanted to use a rotary switch that limited me to 2 circuits versus the 3 circuits that a jake specific toggle switch would give you. Since others have said 1 jake head doesn't do much I didn't feel bad skipping that one and giving myself the option of either 2 or 3 jake heads operating.
Hammer
402
Winlock, WA
Ok, two and three is better than one and three.
And I definitely like the look you have on the switch, no arguements there!
Btw, really nice job getting these in under the hood. I can see other people doing this now! I know if I get back around to messing with my M818, I will copy what you have done for clearancing, etc.
US6x4
2,591
Wenatchee, WA
Thanks for the compliments - much appreciated. I know before the surgery on the hood was a big deterrent to quite a few folks but the hack & whack on a valve cover is far less scary. I imagine M818s are more likely to need jakes than cargo variants like mine, but my jakes are mostly for fun and also a little bit of redundancy in the stopping department. :)
Hammer
402
Winlock, WA
Yeah, any extra braking on these trucks is always a good thing.
And I will use my M920 for any big hauls, but the M818 is still more maneuverable in tight places.
US6x4
2,591
Wenatchee, WA
I've been reviewing the video of my test trip and I notice that the jakes shut off properly when the RPMs are 1500 or above, but when the RPMs are less than 1500 I get the hesitation for the rear head to shut off. The manual button on the solenoid never stuck in the down position so I'm leaning toward control valve inner springs being the cuplrit and they are in the mail so I'm hoping that fixes it.
US6x4
2,591
Wenatchee, WA
Found the culprit to the rear head not shutting off right away; broken inner control valve spring on cylinder 6.
New spring | old spring (cyl. 5) | outer spring
Cylinder 5 spring | cylinder 6 spring
