Dewey BAPU 3500 watt mobile setup
Falstaff
Valley Springs, CA
Here is a photo of my completed BAPU setup. I bought a spun aluminum 5 gallon tank and some fittings, mounted it the the frame (which is aluminum btw) it works quite well. Other rhan the fact that it wake the dead because its so freaking loud).
Anyway, now i am waiting for my 24 volt inverter, my plan is to use the BAPU to charge an array of batteries and use the the inverter for with the BAPU off most of the time at our bug out cabin.
I am into this for:
725 for a legit like new 5 hour on clock Dewey BAPU
125 for the tank
12 bucks in fittings
About 9 bucks for the 3 HF casters
I cant think of any orher system that could charge batteries at this rate for any less (140 +amps at 24v)
(The alternator says its 200 amps!, but i dont think the l100v is enough to handle a 200 amp load.
Anyone know how well a a 24v 3000watt (or bettwr) inverter would work connected direcly to the BAPU terminals?
Falstaff
Valley Springs, CA
Where you ordered a fuel tank? How many gallons on it?
I ordered the tank on Ebay, search for “spun aluminum fuel tanks” It is 7 gallons. I had to drill a hole in the filler neck and install a through hull style fitting for the return line. This didnt work as well as i planned, it really needs to have a bung welded in. If you can find a tank with a return line fitting already welded in on the top, that would be the way to go.
The spun aluminum tanks are very cheap, but i couldnt find one with a return fitting already installed
CPYoung66
Windham, Maine
I’m trying to understand the wiring set up. my intention is to use this to back up my 24 v solar set up off grid, just to charge the battery bank when there isn’t enough sun.
i need to connect battery to run the fuel pump, but is there a different connection location for connecting to the battery bank? I seen mention of a 3 position switch but don’t know how/ where to connect it. Prettty new to this & solar stuff but trying to use what I have….appreciate any help or suggestions where to get info
