Aftermarket gauge cluster for the squarebody vehicles??
ballencd
101
Columbus, NC
Has anyone used the Dakota Digital (RTX/HDX), New Vintage USA or Classic Instrument gauge clusters designed for the Chevrolet/GM Squarebody vehicles? I'm specifically updating my 1991 V1500 Suburban with bad odometer, incorrect speedometer and no tachometer and wanting to update to have all three but haven't found any user input as to quality, longevity or difficulty of install of these brands. Any help would be appreciated.
Thanks
ballencd
chevymike
486
San Diego, CA
I have used Dakota Digital in a number of builds (not a squarebody but other C10's and El Camino) as well as a couple buddies. They have worked great and love the look and function of them.
About the only issue I have had, it more my own install related. You MUST keep the wire for the speedo sensor away as much as you can from any tach signal wire or the spark plug wires. The interference from them will cause the speedo to do weird things. Once I would get the cable routed correctly, no problems. So far running for 4+ years in my El Camino.
ballencd
101
Columbus, NC
Thanks for the input. I wonder if one could use shielded coax for the signal wire and ground the shield? I am about to bite the bullet on one of these clusters so your info will help. Anyone have input on the Classic Instrument or the New Vintage USA clusters?
chevymike
486
San Diego, CA
I believe it is a 3 or 4 wire cable. I had actually bought some braided sleeve that I was going to use but figured out I just needed to move the cable on the frame away from the rear spark plug wire. Problem went away so I never used the sleeve. I actually have an HDX setup that will go in my '55 Chevy, when I get to that project.
I have seen both of the others used in many cars at shows I attend but no personal experience. I had a buddy who had Classic Instrument individual gauges and they worked fine but he switched to Dakota Digital in his Nova as it was a much nicer setup. If you are looking for individual gauges, I have used Speedhut gauges on three projects, including my M1010. They were custom made specifically to my design.
ballencd
101
Columbus, NC
That looks nice. I like the green.
socalsrt
22
california
I have the Classic Instruments cluster. As with everything, there are some things I like and some I do not like. It is nice having an electric tachometer and speedometer. None of the factory gauges were working and my engine swap electronics had the capability to run electric gauges with no additional work. I shopped around and went with Classic Instruments. Installation is easy and it does have a nice clean appearance. Installation on a 6.2 would be slightly more difficult. You would need a signal converter on the speedo cable. I am not sure how you could run the tachometer on the 6.2. I have attached a picture of it at night. I try not to speak badly about specialty products on the net, so feel free to send me a message for more info or pictures. For what its worth this is an accurate picture depicting the lens. On my next motor swap I will probably look at other brands, however I wouldn't be surprised if I purchased the same one again.
Skinny
559
Portsmouth, NH
I'm going to bet that any gauge swap on a CUCV is going to be wire intense since we are talking about a complete retrofit from 80's technology.
Speedo signal is no issue. You can use a $25 hall effects pickup on the tcase just like stock 90's factory stuff.
Tach signal of it is a diesel tach will come from the alternator w feed which essentially is single phase AC voltage. Now this will have to be calibrated since the tach doesn't know how fast the alternator is spinning in relation to the crank. I used a free app on my phone. Drive down the road and take a reading, recalibrate. After about 4 tries it is spot on.
Temp and oil are going to need senders that match the gauges. Simply reuse the factory wires with the new senders.
I will say I like to look of the NVU Aviators. They do require a ton of fitting since they mount to a board that bolts to the sheet metal. I'm guessing any gauged retrofit that goes this way suffers from the same trouble compared to one that mounts to the back of the bezel.
Sent from my Moto G (5) Plus using Tapatalk
ballencd
101
Columbus, NC
I went with the Speed Hut gauges and like them. I don't like the rear leaning I got using the factory bezel so will be re-doing the dash at some point but I needed them to be in the vehicle since the odometer was not working and the speedo was not close to accurate. I like the tach addition. I ended up cutting the bezel with a die grinder until the gauges fit. Piece of cake.IMG_3040.JPG
ballencd
101
Columbus, NC
Started back on the gauge install. TIG welding in not the best but it is my first project on aluminium. The gauges are leaning back toward the dash so I can see them now. Still working on the top of the dash. My plan is to contact cement leather on the aluminum or paint with bed/trunk paint to hide the spotty welding. I think the top will be aluminum too.
als804
66
kimcheon, ROK
Can you show me more this looking good cluster? Or info of dimensions? This is really what i wann do
ballencd
101
Columbus, NC
Not much more to show at this point as the project has been on hold for quite some time since they were installed. I bought Speed Hut gauges...Speedo, tach, oil pressure, water temp, volts and fuel. I've been driving the suburban without the top of the dash for a long time now but plans are to finish it one day. I've seen, I think, on a GM squarebody site a guys used about the same guages but smaller tach and speedo then mine and mounted them all in the factory bezel and they looked pretty good. I think he used 4" for the tach and speedo. Mine are 5". A am planning on putting a flat plate of aluminium on the top of the dash and somehow tie them in with what is already mounted. I couldn't justify the $500 + shipping for the replacement dash and mine was crumbling when it came out.
chevymike
486
San Diego, CA
Yeah, I did that and cut down the bezel on the small gauges, to I could mount them and the pointed towards you, like factory gauges.
I used the 4" gauges for speedo and tach and didn't have to grind anything, as they recessed in like stock.
